Hi All,
I have xperia arc s model LT18i, ver 2.3.4, kernal ver 2.6.32.9, build 4.0.2.A.0.42.
My sony ericsson pc companion shows there is an update for build and its 4.0.2.A.0.62
The problem is when I' am trying to update, on the preparing the computer section,
its showing 'sony ericsson server is currently overloaded. please try again later'. Its happening since a week continously.
How can I update it. Is there any other way?
Thanks
S
Hi, suggest you try SE Update Service. Here's the download link, http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe. Just make sure phone is switched off for this process.
thank you so much.. it worked..
No problem.
