n not for turning on and off.
I can not turn off or on the smartphone
've tried FlashTool and PC companion..
i'm from Brasil, my english is very bad.
does the LED turn on when you connect it to the wall charger? if it does, let it charge for an hour or so and then try with SUS
unrelated topic, if you have some time please check this thread
if it doesn't, connect it to the wall charger > press and hold both power button and volume up at the same time, hold them for 5 to 10 seconds (until it vibrates) let it charge for an hour.
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
for future reference
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
