Are you willing to try a software repair via sony update service?I must tell you it erases phone memory.
Try settings-apps-all-bluetooth share,force stop and clear data.
How about force turn off the device?
I am glad you sorted it out.
Have not tried it yet?
How about smart connect?Have you tried clearing data for it?Settings-apps-all-smart connect.
