When I try to connect my BT mouse to my brand new phone, it doesn't seems to work : in the bluetooth parameter the mouse is "paired but not connected".
Is there a way to make it works ?
You are correct Nabeel, this particular function is simply not supported outside of the USB OTG function.
What are your thoughts about this forum? Let us know by doing this short survey.
its impossible to make it work that way i think, if i am not wrong
for it you need a live dock/ smart dock ( i think smart dock is meant for xperia s )
that too i am not sure, but the way you are connecting is impossible
Yes it's true, i've tried the USB OTG (bought on ebay for 3€ :smileyhappy:) with microsoft wireless desktop 1000 and it works fine... I hope that Sony Xperia S in the next firmware will be compatible with bluetooth HID device.
bye Antonio
Just uptated to ics it works!
