when we open the service menu and scroll down to battery test and tap on it..
its wriiten
"battery test may take hours"
and when clicked on ok the phone goes to airplane mode..
so my question is how to use the battery test feature ??
do we have to leave the phone for couple of hours or use it and side by side battery is being tested ?
This is what I've figured out about the battery test.
Use your phone until it's fully de-charged and turns off. Then connect the charger and let it charge till the indicator shows full battery (do not power on the phone, charge it powered off)
When the indicator shows full battery you power on the phone, enter the service menu and battery test. (Charger should still be connected)
When result shows testing you unplug the charger and let the phone de-charge till it comes back with a result for you, I think it needs to drop to 70%.
It will sure take some time to do this test.
yay finaly
ok..got it
yes 30% decline will take like forever
since the phone will be in airplane mode..
and will consume minimum battery..
thanx for this
also..
what was your phoe's result ??
if i ever checked mine..i can compare with yours
So is the purpose of this test to find out if your battery is discharging at normal rate?
up..
