Hello,
I have fully charge my phone but its work only 5 hours.
Screen takes 30 to 50 percent battery.
Anytime.
Most of my Xperia Sp battery is drained by "ANDROID SYSTEM"(35-50%).
And moreover "ANDROID OS" takes upto 3-4% battery.
In most of the phones there is no battery drain by "ANDROID SYSTEM" so why in SP? And the battery used by "ANDROID OS" is 3-4% only.
Hi there,
I recently changed my phone to the SP less than six months ago and i have had nothing but problems with this phone. Battery life i awful, i am losing on average 10-15% battery iife per hr, and this is without using it. Wi-fi, blue tooth, background apps are all switched off, yet day by day the battery life is getting worse. I can no lonnger leave the house without making sure i bring the charger with me. On average i am getting less than 7 hrs a day of usage from the phone without having to charge it up. Its not as if i am using it for email or phone calls as i have a work phone for these.
Secondly when i do open apps, such as messages etc, i am continually getting a message saying "app is not responsive, do you wish to wait, close or report". AAAgain this is happening every single day, i have tried uninstalling apps such as facebook etc but problem persists. Thenn the phone will just sometimes decide to switch itself off and i have to wait 20 mins to tru and get the phone back working.
Tis is my very first sony phone andd it will def be my last, i am just so fed up with the problems i am experiencing with this make. Any help would be brilliant, before i resort to using two cans and a piece of string attached to them as an upgrade to my current phone.
