Are there someone else experience battery overheating in LWW with ICS?
Using a app like Battery Disk you can check the battery temperature. In normal conditions, the value of temperature is about 29°C,
but after use some new features, like face unlock, the temperature goes to 34°C and you can feel it in the palm of your hand.
Why this is happening? There is a solution for this?
If someone of sony team answer I will apreciate, also the other ones who answer that.
Best regards.
Experiencing heat from the device is normal as this is based on the hardware within the device. However the handset will never get to a point where it is to hot to hold or use. If you believe the handset is becoming to hot then I suggest getting the handset to a service centre for assessment.
