Some basic info, please.
1. User Guide, phone based: Updated software. After date restore, could not access phone user guide, had to go online.
Followed tip to download & install replacement. Found the original where it should be in phone's folder. (Guides were different sizes.)
Replaced existing guide. Now the user guide logo has disappeared from the list.
How to activate phone based guide?
2. Google mail: Cannot access contact list. If I want to compose an e-mail, I need to know who to send to ahead of time,
And I need to type in the full address each time.
Ideas on how to access contact list?
3. Contact list (phone): I have 1 registered gmail account. When I enter a new contact in the phone, the info
gets replicated to the gmail entry - twicw. Scrolling down the contact entry shows a duplicate entry for the google account.
How to remove the duplicate?
Thanks
transfer all the contacts as they are right now to Gmail, and you can continue to modify them on your computer, then you will delete ALL the contacts from your phone so you can sync ONLY gmail contacts (then you can create a backup of your contacts on your phone)
I forgot to say, before you start with this, go to:
Phonebook app
Edit all your contacts, yes it's a pain in the ... but it won't be later on, delete duplicates, add emails etc.
there are two simple options for number 2, one you can access your gmail not with the app but with the browser, now scroll to the bottom and it will say Desktop click on it and you will get the same options as if you were using your computer.
option 2.
first you need to sync your contacts from your phone to your gmail.
The reason for this is because you are syncing with multiple accounts
go to
settings
Accounts & Sync
under Manage Accounts tap on each of the accounts you're currently syncing with and select what you want to sync if you follow the steps above do NOT sync contacts with any other account other than Google.
I don't quite understand your question
do you want the online guide on your phone? or do you want to "Restore" the user guide on your phone?
Restore the User guide in your phone
If you have lost the User guide in your phone when updating the phone software, you can download the User guide to your memory card using a USB cable.
To restore the User guide in your phone
Note: Do not disconnect the USB cable while you are transferring content as this may corrupt the content.
To disconnect the USB cable safely
To access the User guide in your phone
Thanks for the tip.
Results:
After the software upgrade, the user guide app still showed on the phone, but I could not access it on the phone.
After reviewing this answer, I downloaded the user guide, renamed it, went to install it in the "others" folder and saw that the user guide was, in fact, there.
I replaced it with the downloaded version, now the app icon has disappeared from the main apps listing.
I did copy the icon to the main screen before replacing the file. That icon still shows, but has a small black text box under it with no text. Tapping on the icon gives me the message:
"Application is not installed on your phone".
you can try using Astro File Manager
https://market.android.com/details?id=com.metago.astro&feature=search_result
or other File Managers to get access to it on your SD Card
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
regarding the contact list:
before i do any more, can you clarify?
in the beginning, i had the phone contact list with a few entries.
then i added a single gmail account.
after that, when i looked at a contact, i had one set of data fields for the phone list and 2 sets of data for the gmail account.
unfortunately, i synched my contacts using another method that you outlined (brain, brain, don't fail me now) - I (think I) did this from within my gmail account on the computer.
from the entries now in the contact list, i must have provided my regular e-mail address.
i just reviewed my entries on the phone.
now i have some separation.
there seems to be 1 entry for phone contacts & 1 for gmail where there is a name mismatch (e.g. bob = phone entry; bobby = gmail entry)
in some cases there are 1 phone entry and 2 sets of gmail entries like before, in other cases there are 1 phone & 1 gmail.
i would like to straighten all this out to ease finding contacts & using the phone.
what do you suggest? i could remove the account from the phone & start over or ...
thanks
When you renamed the file did you rename it 'emanual.zip' cos if you did then try renaming it again to just 'emanual' and the .zip is added automatically. If you use something like LInda file manger it actually shows you the file extensions and if you follow the instructions (which are wrong and have been reported) you will have a file called emanual.zip.zip and the phone just won't see it.
ah, the vagaries of the directory tree.
i will make the change when i get back to my home base.
thanks
Let us know how you get on!
