Does it work at all?
How about if you test your phone with
https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.functiontester
I use "YAAB" or Yet Another Auto Brightness app. Works beautifully, even better than stock
Excelent
Works perfect
Thank you
I have sony xperia C4 dual, the touch and display has been changed but after this the brightness is not bright as earlier before changing the display.Although it is on full bright mode.
So what is the solution for it.
Please tell me.
