Hi Team,
i Have an XP SP with the latest official update of 4.1.2 and build number of 12.0.A.2.254 ,even though i select the option of auto brightness adjest ment in the display options of Settings the feature doesnt seem to work .I mean to say when i walk out to place with direct sunlight were the auto mode for brightness is to increase the brightness of the Display it Does'nt.
Is It a problem with just my phone or all the other phones of SP as well.
Kindly let me a solution .Does this issue be resolved in the awaited 4.3 update for SP?
Have the same problem.
Hope 4.3 solve шею
thnx.
When can we expect 4.3 update in India .
SUS is never the option i had already done it as soon as i found i had this problem .
Kindly let us know if there is a real solution for this problem kindly dont drag for this solution.
I have the same problem, seems like it is not solved in any software update.
The Sony brightness handler is borked imo. Didn't work for me on any version of firmware. Vellis Auto Brightness fixes it.
Dave
