My arc s wouldn'd update. I keeps popping up errors in the download section. saomeone please help urgently
Try isntalling/re-installing SUS -> restart your computer -> turn off your firewall and/or antivirus -> run SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget to Correct Answers & Helpful Answers
Can you elaborate which errors? which method are you using?
Error;
Unable to install or start Phone Software update components
did SUS worked for you?
if you don't have 4.0.4 and you don't want to wait you can do this
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
