any one please help me i juxt bought a new arc s but its cam quality is tooo bad please help me with this problem
play with the settings -> use the shutter instead of touching the screen aside from that there isn't much you can do to improve quality
go to settings -> about phone
which android version and build number do you have?
elaborate on the camera issues
bro its android v 4.0.4 and build no# 4.1.B.0.431
camera quality is very sucks in bad lights i bought this fo9 only for 8 mp camera but i m very disappointed with the result
my c905 was 1000 times better then this one
Message was edited by: Sidds
that's as good as they are going to get, they are over compressed.
didn't get ya bro !! any suggestions any tips plzzz share with me 😕
is it a hardware problem or a software problem ????
seems more of a software issue, it has the same sensor as the iphone 4S
it means i m not the only 1 who is facing this issue ?? well i hope sony will do sumthing for this problem
no, you are not the only one facing this issue, even with the new 2012 Xperias the issue is still there
check this thread
http://talk.sonymobile.com/thread/36192
