Please Help..
My internet connection is works fine..
But most of my apps (Whatsapp, FB, Twitter, etc) are not working as well..
This is happen after updating to Jelly Bean 62.B.0.200..
My Phone is Xperia SL..
It is likely that you have what is called WAP settings as opposed to Internet settings. This will cause most basic internet functions to work but almost no apps will be able to connect. Please check with your current network provider to confirm this.
What are your thoughts about this forum? Let us know by doing this short survey.
download speedtest and check your connection
do you have any taskillers or battery apps or antivirus?
Thank's for the solution, but the real trouble is my internet setting..
Correct sam.. I've downloading 'internet setting' which provide by my network provider and the connection back to normal...
Thanks..
Sam, when will JB.211 rollout in Indonesia.?
