HI,
I have xperai ray with 3g sim, when i enable the data connection non of the app such as gtalk, viber etc work whereas internet over browser is fine but when i connect the phone using wifi then both apps and internet work normally. Please let me know if there is any option to enable app work on data connection using 2g or 3g internet.
Thanks
Bawer
there are simillar threads to this. try to contact your network provider for proper APNs, sometimes they use different apns for different network uses.
