Almost all the applications stop responding at the same time and a pop up show all the ANR appears...
how to resolve...
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
could you post a screenshot?
this is only a single ANR many ANR pop ups appear at the same time for many applications & also the phone hangs for about 10-15 minutes
uninstall the following apps
taskillers
task managers
antivirus
ram apps
booster apps
battery apps
or repair your phone with SUS or PCC and do NOT install any of those apps and uninstall mcafee > check again.
Bridge (for Mac)
I don't have any of the above applications installed except antivirus (Zoner Mobile Security) should I uninstall that & the phone will start working fine as before but If I uninstall the antivirus will the phone be safe from virus attack
you don't need an antivirus this is Android not a PC, just repair your phone
Bridge (for Mac)
Repairing will reinstall the current OS, It sounds a bit risky as there are many a users who have complained regarding the update issues, can I just uninstall the antivirus & will the phone work fine or repair is compulsorily needed.
I don't understand what problems will arise from repairing your phone.
Is it completely safe ???? the current OS will completely get installed or some files may remain missing....
I don't much but thats only my doubt......If safe I will repair it
