Hi, i am using xperia p.. and i am having this problem, android.process.acore has stopped. none of my appplications are working.. can u pls help...i am using 4.0.4(LT22i) . Thank you.
this is another alternative
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
have you disable any apps?
no not yet.. even if u remove the sim same things are happening... what should i do??
try this
settings > apps > all > contacts > clear cache
also it will be wise to create a backup of your contacts
i think i am backed up... what should i do next??
contact also not working.. no idea how to back up.. is ther any alternative???
Bridge (for Mac)
ill update and get back to u.. i tried many times cant even back my contact by any means because none of my apps are working including contacts,ph,msg,calenadar etc...
Thanks a lot for u r time.. the infomartion was veryhelpfull and the phone is working better than before... and new version is so cool... thanks again..
anytime
