The normal add widget doesn't work anymore.
Tried http://www.technipages.com/galaxy-nexus-add-resize-and-remove-widgets.html
http://www.talkandroid.com/guides/beginner/adding-widgets-to-android-home-screen/
No widget tab there, anyone know how to find the widget screen?
Just tap on the empty screen. You can see a little plus icon on top right corner. Tap on that and you will be able to add widgets on to your home screen.
Ok, liked the old way much better.
Same here. But this is how it is in ICS.
