Hello
My phone displays the following error:
Activity Home screen (in application Home screen) is not responding
I cant open the menu or do anything. Any ideas on how to fix? Thanks.
Regards
Danfoss5000
http://www.sonymobile.com/global-en/tools/update-service
update your phone with this..it will solve the problem..
I agree with Slimshaddy, this should resolve the issue.
keep us posted
thanks guys i will try it and let you know..
thanks slimshady that worked heaps wicked good
great
Thats great news. Hope all goes well for the future.
Hello, i recently bought an xperia arc s, it is a week old and already i receive the error message: sonyericsson home is not responding, it happens often and is verry annoying. I tried using the update service but the phone came with the latest updates , so none are available. Can anyone help ?
just click on install anyway
i mean re-update your phone , it will be good as new..
Agreed, I would install the current software on the device as well it is very likely to resolve the problem.
