Hi there,
Another unhappy user here. I just got Xperia SP and first thing I did was applying 4.3 update using Mac Bridge app with factory reset option (before even reading about all the troubles 4.3 introduced).
Now, I haven't installed any 3rd party apps yet. Just SP 12.1.A.1.201 firmware with polish Orange branding and software.
I configured my three email accounts (one Exchange, two generic IMAP) and activated autosync. No WIFI connection configured yet (so WIFI is off), only mobile data is active.
In such configuration, activating STAMINA mode makes my phone reboot itself a few minutes after screen goes blank. Every time! Of course phone gets hot because of that, battery goes down, recent apps list is cleared.
I reflashed the phone using Sony Update Service. Same result.
How is it possible STAMINA, a function Sony advertises so much, is broken in such basic config? Does anybody else have the same problem? Or maybe Orange screw something up in some bloatware they added?
V.
I confirm
This is a problem Stamina Mode and APN ipv6 (For example Orange Poland)
Just change the APN to manual for ipv4 and the problem disappears.
Jacek
