Has anybody had any issues turning off haptic feedback? I've un-checked it in the Settings > Sound menu but it still vibrates every time I type in the keypad or browser.
Thanks
on the browser app or messenging app once the keyboard appears tap on the wrench icon -> uncheck vibration on press
Worked a treat, thanks very much.
anytime
HI
i just got my Sony Xperia z3 compact .
this solution did not work for me.. every time there is a sound ( like when you send a Whattsapp i get the Haptic feedback)
any suggestions?
regards
Spike
i actually just googled haptic feedback...
what i have is not that!..
after every notification noise, there is a vvvvvvvvvvvvvvvvvvvvvvv noise that follows... like a speaker makes with you plug a microphone in ...
its not a vibration but a noise...
ive watched every youtube clip .....
unless phone is faullty...
please help!!!
