Hi
I have an Xperia X10 mini. Please could someone tell me how to access the SD card. I can access the album and the music player independently but would like to see what is on my sd card. I cannot seem to find a way to access the card.
Thanks
Linda
Hello Linda
Well all you need is to go on to the Market and search for your name cos there is a file manager called Linda that lets you see whats on your sd card. I also have Astro file manager, you can have both - they have different advantages ie Linda lets you reinstall downloaded apps and Astro has its own Viewer for pictures etc which is useful at times.
Happy searching!
Hello Linda
Happy searching!
Thanks Suze. That's really helped.
No worries, glad to have helped.
dear suze!!!
i googled the lindA FILE manager and found a link, they have a neo code, i entered the neo code reader on my phone, faced my phone to the screen , it recognized it, but when i press ,,continue,, it doesnt go to the web page!!!!! i feel frustrated!!!! i want to use the phone with all its possibilities which i payed for!!!!! is there another way to download those stupid file managers? and why doesnt SE already incluse a file manager in the default menu?
i want to be happy with my phone!!! i think i will switch to nokia
er .... I think Suze is busy rite now, she will be back soon.
About your problem, can't you just download it from Android Market?
any code that i scan it says ,,no matches found for......
DOWNLOAD IT FROM ANDROID MARKET DIRECTLY FROM YOUR PHONE. you just need google account and wifi-data connection. ENJOY.
Try this ....
ok. i have connected to wifi, the picture is too small, the phone doesnt get a clear image of it
why in the whole world did SE made it so annoying?!?!!?
