I updated my Arc to ICS yesterday and when I navigate to settings -> wireless & networks -> mobile networks -> access point names , I get a message "Unfortunately the settings has stopped"
Also at times my internet connection drops in which case i need to do settings -> Device (Xperia) -> Internet Settings which will again download my internet settings and restores my mobile internet.
It was working perfect when I was on GB but now in ICS 4.0.4 i am getting this error... appreciate any help on this!!
Cheers!!!
Hi, sugges you reflash firmware again, probably the earlier update was somehow corrupted.
Thanks for the suggestion.. will try and update on it
No problem ....
