I know the Mini Pro *officially* supports up to 32GB. I read that some devices do support a 64GB card even though they only officially support 32GB.
Can anyone confirm or deny that a 64GB card will work with the Mini Pro?
SD card above 32 GB may not work properly , or may not work at all.
1) Your mobile may become exremly slow,
2) It may show only 32 GB as free
3) Card not being recognised
4) Low read/write speed
Most probably it won't work
Yes, I know it's not officially supported, may not work, etc, etc.
What I'm asking is, has anyone actually tried using a 64GB microSD card in their Xperia, and did it function properly or not?
Thank you Nabeel
