In white paper of Xperia J is written that smartphone have 512MB of RAM. But when I run shell command 'free' via ADB i get 380MB. I found other topics about this issue but they do not explain the memory usage. Regardless of how much memory is used up, the 'free' command should show the list of whole, free and consumed memory. For example:
root@android:/ # free
total used free shared buffers
Mem: 389780 382172 7608 0 10672
-/+ buffers: 371500 18280
Swap: 0 0 0If the Xperia J had to actually 512MB command 'free' should show:
Mem: 524288 382172 142116 0 10672
Swap: 0 0 0Maybe the memory is somehow locked to, for future use in case of an update.
I don't have details about what hardware that has RAM reserved but i do know that some is reserved for GPU and in some models also for the camera.
If you want more detailed information about the use of memory i think you need to use the developer channels (http://developer.sonymobile.com/about/how-do-i-get-in-contact/).
The phone has 512MB RAM but not all of that is available for apps and Android. Some memory is for example used for the graphics and some for the kernel. The command free will not show you the total amount of RAM the phone has.
I'm not asking about the memory available for applications. If the remaining memory (132MB) would be visible to the kernel, it can be see in /proc/meminfo summary. But it is not.
Unless it is a 132MB graphics memory, that I'll understand.
I don't know how much RAM that is reserved for the graphics alone but from what i've been able to find there are also other parts that uses memory that you can't see like the kernel and other hardware parts.
