My phone is Neo V, I have just upgrade to 4.0.2.A.0.62 and found that cannot disable function Haptic feedback (Vibrate when pressing soft keys and on certain UI interactions). This function is fail, when i touch any number to dial or edit message, the phone vibrate, cannot disable it. Who have the same problem and explain to me? I think SE should have new firmware to improve this one as soon as possible.
Try this ....
Launch Messaging app>New message, tap 'Write message' area to access keyboard, tap the wrench icon (bottom roll, 2nd icon from right), then untick Vibration on keypress.
go to settings -> sound scroll down and uncheck haptif feedback screen lock sounds, audible selection audible touch tones
I did so, but no change. Any another idea? Thank you.
open the messaging app -> tap on the wrench icon -> uncheck vibration on keypress
or on the homescreen press and hold the menu button -> tap on the wrench icon -> uncheck vibration on keypress
Thank you. On My SE Neo V, I didn't see item Vibration on keypress. And I don't see icon so call 'wrench icon', do you mean Settings icon?
Hi, what input keyboard are you using?
I use default keyboard from store, don't change any thing. Before upgrade, this function can be disable, after upgrade, it isnot active.
Thank you so much, it is OK, removed vibrate from masseging, but how about dial key board, it still vibrate every touch.
Unfortunately, I don't think there is any way to disable that for the Dial Keypad.
