i tried to unlock the boot loader for my xperia m. but just after finishing the process it got into a bootloop. I couldnt check wether the bootloader is unlocked or not as i couldnt start up my phone T_T . Flash tools dosnt recognize my phone too. Can any one please help me? Please guys... thanks:smileyhappy: Btw my phone is 4.3 jelly bean
I don't quite understand did you or did you not, unlocked the bootloader?
How can we check? i finished entering my KEY in command prompt.(official bootloader unlock process from sony 16th step). Than i ended up in bootloop.
please help guys...
Does Flashmode work or Fastboot mode?
If not then something got messed up and without any of those modes working then you have a bricked phone - But if it's in a bootloop then Flashmode should be working
the flash mode works fine.(the blue light) but my phone dosnt show up on emma(official flash tool for sony). What should i do?
If you read emma it's not compatible - You need to use Flashtools and a .ftf firmware file if you have unlocked your bootloader - If you think your bootloader unlocked failed and it is still locked then use PC Compannion to perform a repair
i tried reparing from PCC.. but it says that system is modified. Cant update. does that mean i unlocked the bootloader? what should i do next? and thanks for helping me:smileyhappy:
oh... sorry. i just saw the supported devices of emma and Xperia M is not listed. Can you please suggest me a flash tool for Xperia M?
