Hello,
Can anyone please help me to use wifi direct in my Sony xperia M,there is no option to send files using wifi direct as well as no option to send using NFC.Share option does not contain NFC and WiFi direct it shows Bluetooth and other options except NFC and wifi direct.
Any help is appreciated.
thanks in advance
yeah after searching when it finds a device u connect n transfer.. see that the opposite device is switched on , supports wfi direct/nfc and has it enabled.
Okay,i'll try that once again and let you know
in case your problem is solved Saurabh then plz mark the thread as solved.
yes sure i wil do that as soon as i check it,i was litle busy so will mark solved ASAP.
I tried and both devices shows connected but now if click on connected devices it only shows option to disconnect,
there is niot actual option to send media/files using wifi direct.
any help is appreciated...
Sony support center's reply to the issue.
Turning on Wi-Fi Direct
Android 4.1 / 4.2
To turn on Wi-Fi Direct
Sending files using Wi-Fi Direct
The advantage with sending files with Wi-Fi Direct is that it goes quicker to
send larger files than with, for example, Bluetooth.
To be able to transfer files between two devices you have to:
Downloading Office Suite
To download Office Suite
Sharing a photo using Wi-Fi direct
To share a photo using Wi-Fi Direct
its really simple actually is nt it???
use office suite application provided by sony in the phone to share with wifi direct.
