Hello,
Can anyone please help me to use wifi direct in my Sony xperia M,there is no option to send files using wifi direct as well as no option to send using NFC.Share option does not contain NFC and WiFi direct it shows Bluetooth and other options except NFC and wifi direct.
Any help is appreciated.
thanks in advance
Sony support center's reply to the issue.
Turning on Wi-Fi Direct
Android 4.1 / 4.2
To turn on Wi-Fi Direct
Sending files using Wi-Fi Direct
The advantage with sending files with Wi-Fi Direct is that it goes quicker to
send larger files than with, for example, Bluetooth.
To be able to transfer files between two devices you have to:
Downloading Office Suite
To download Office Suite
Sharing a photo using Wi-Fi direct
To share a photo using Wi-Fi Direct
Thanks for the reply,but according to that guide it only searches for wifi direct enabled devices and makes peer connection.
but there is not optin to share files using wifi direct,i want to share fiiles between two devices using same function.
share optin does not show option of wifi derect or NFC as it shows share with bluetooth.
There are myriad apps on the play store
Doesn't sony provide inbuilt option for the same rather than downloading third party app?
they have given wifi direct and nfc so they must give optin to use the same,dont you think?
The great thing about Android is that you don't have to rely so heavily on the OEM as you can download apps to customize your phone as needed.
That is correct,but it would have been better if sony implemeted this function in OEM itself.
hope they include it in new updates.
NFC
SETTINGS-WIRELESS AND NETWORKS- MORE-NFC( TURN IT ON) - ANDROID BEAM (TURN IT ON)... Now you can use NFC to beam videos, apps, contacts etc..
WIFI DIRECT..
SETTINGS-WIFI- .. TAP THE THREE SMALL DOTS ON THE EXTREME BOTTOM RIGHT OF THE SCREEN...TAP ON THE WIFI DIRECT OPTION ... ENJOY
Thanks but this option only enables and searches for devices,nothing else
