It could have been Sony pulled the update or it could be your country requested that it be pulled or it may have simply been an error with the labeling but to be sure contact Xperia care and ask about this update http://support.sonymobile.com/gb/contactUs/
@rockyrocky Please don't create new post/threads on this topic, you already have an answer
If the update was available you should be able to download and install it, check through PCC if its not there well then the update has not been rolled out.
Bridge (for Mac)
Alternatives on How to backup Xperias
are you sure the update available wasn't for PC Companion itself not your phone? you are not going to find any other answer here other than contact your local Xperia Care or check your phone
settings > about phone > software update
or
PC Companion or Bridge (for Mac)
other than that you will have to wait
OR
manually update your phone.
