Settings > apps > all > file commander > scroll down > clear defaults
Hi misscooke666,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Make sure to make the change within the message settings.
Menu > Messaging > Settings > Notifications
This should help resolve the issue.
