why xperia m 4.3 with firmware 15.4.A.0.23 not support theme?
and why xperia keyboard not have a phonepad layout?
why?
Spiderman theme https://play.google.com/store/apps/details?id=com.sonymobile.themes.spiderman2&hl=en
Pink hearts https://play.google.com/store/apps/details?id=se.knowit.mobile.pinkhearts&hl=en
Comic pirate https://play.google.com/store/apps/details?id=com.sonymobile.comicpirate&hl=en
Winter snow https://play.google.com/store/apps/details?id=se.knowit.mobile.wintersnow&hl=en
NOIR https://play.google.com/store/apps/details?id=se.thegreen.themes.noir&hl=en
Craftmanship https://play.google.com/store/apps/details?id=se.thegreen.themes.craftsmanship&hl=en
Woody https://play.google.com/store/apps/details?id=se.knowit.mobile.woody&hl=en
Triflat https://play.google.com/store/apps/details?id=se.knowit.mobile.triflat&hl=en
There are others listed on Sony select but they are the free one's
How do you mean it doesn't support theme?
Unfortunately phone pad layout is not longer available in the latest software. I don't have any specific information why.
@Alexander wrote:Hi,
I think he means this:
http://talk.sonymobile.com/t5/Xperia-M-M-dual/Xperia-Themes-not-installing/m-p/616499#U616499
Hi Mr Alexander
Why android 4.3 Xperia M can't use Xperia Theme? from this blog sony mobile explains that all android Jelly Bean Xperia can use Xperia Theme so easy.
An XM if you click + on the top-right corner at theme setting just link to download theme apk you can't install those apks
Open Sony select - Choose themes and select the theme you want - Open said theme with Google play then once installed open themes and select the new theme
thanks bro but unfortunately those still not working on my XM
Check the other themes from one of the developers from above https://play.google.com/store/apps/developer?id=Knowit%20Mobile%20AB&hl=en
and the other developer is here https://play.google.com/store/apps/developer?id=The%20Green&hl=en
You must be either unlucky or have an app installed restricting this - What country are you in as this may be a regional restriction
I try to open your link and still ...... This app is incompatible with your device.
