I installed song bridge for mac to update my address book with the phone xperia m.
When is asked to allow access to address book i acccidently clicked "Dont allow"
now when i try again it wont ask that qustion.?
How to i get the app to ask that question again?
Please advice
Vikaspell
I just found the solution.
I am posting this so if someone else has the same problem they can apply this.
go to system and preferences. -> security and privacy --> contacts...
there when you scroll down you will see the application song bridge.
you can enable it there
thanks you
vikaspell
I would suggest that you uninstall Bridge for Mac and then restart your computer. Install Bridge for Mac again, and hopefully you will get this request again. I'm not sure but I think this is more a setting for the contact application that you are using on your Mac than Bridge for Mac itself.
I uninstalled sony bridge and restarted the mac.
THen reinstalled the app. but still it wont ask me to question ?
Is there a workaround.... i feel so stupid?
vikaspell
