You can't
http://support.sonymobile.com/global-en/xperiam4aqua/userguide/Still-camera-settings/13MP
4128Γ3096(4:3)
13 megapixel resolution with 4:3 aspect ratio. Suitable for photos that you want to view on non-widescreen displays or print in high resolution.
9MP
3920Γ2204(16:9)
9 megapixel resolution with 16:9 aspect ratio. Suitable for photos that you want to view on widescreen displays.
8MP
3264Γ2448(4:3)
8 megapixel resolution with 4:3 aspect ratio. Suitable for photos that you want to view on non-widescreen displays or print in high resolution.
8MP
3840Γ2160(16:9)
8 megapixel resolution with 16:9 aspect ratio. Suitable for photos that you want to view on widescreen displays.
3MP
2048Γ1536(4:3)
2MP
1920Γ1080(16:9)
2 megapixel resolution with 16:9 aspect ratio. Suitable for photos that you want to view on widescreen displays.
VGA
640Γ480(4:3)
VGA format with 4:3 aspect ratio.
This setting is only available in Manual capturing mode.
NaznaΔite sviΔanje na Facebooku
