When playing songs most of the times there is a jumping/freeze . It still happens after the latest update to 4.3. I saw a similar post in xperia Z sub-section .It is abit annoying .
Thank you for your time.
Try settings-apps-all-walkman,clear data(for both apps).Restart your phone.
I tried as you suggested . The jumping and freezing happened once at start and then it was fine.
Thank you very much
