Is there any info for when Sony makes fix for Smart Connect bug? (There is no quiet option)
Not sure why Smart connect would need fixing to enable silent mode
/t5/Xperia-Z3-Compact/Smart-connect-isn-t-working-correctly-on-Android-5-1/m-p/1016473#M13496
Reported before. Not sure if anything will be done or can be done. Thread locked.
Ah I see now - Another advantage of sticking with KK
