I'm a bit confused, are you saying that your wife is tethering her phone's data to your computer?
lol, ok, so you are trying to use the wifi but you don't know the password or your phone can't find the wifi that your computer can?
I see, so you are asking if the owner of that router will be able to see you are connecting your phone to it?
Your phone will be seen but others won't be able to connect even if you use Pc Companion the connection has to be started from your phone
