Hi I'm using Sony m4 aqua dual. But I didn't get where should I want to put a 2nd sim.
Translation via Google Translate:
When I put the sim card, I get lost the signal sometimes there is no signal at all! Please Judge!
При слагане на сим-карата почва да ми се губи сигнала понякога въобще няма сигнала! Моля за съдеиствие!
But there is only single port
@uliwooly wrote:Here you go
http://support.sonymobile.com/global-en/xperiam4aquadual/userguide/assembly/
When putting a sim card it starts to lose my signal sometimes even a signal signal! I pray for hope!
