Hello!
When I touch the screen area where I touched surrounded by a yellow square. Why does it happen?
@AG18 You need to use two fingers to move around and double tap to confirm if I remember correctly.
I guess you activated some setting in Accessibility, check in Settings -> Accessibility for Narrator and TalkBack to be disabled.
the problem is that this yellow square prevent me to use the device properly...
OK it warks thanks.
Anytime.
