Hello community!
The screen flickers (and strongest in the lower edge region).
Anybody know something about this problem and what could be done?
Thanks
SoNik
Hello Phy,
thanks, but on safe mode the same problem (the screen flickers continue)
SoNik
no problem was found with Sony PC Companion.
It seems to be an hardware problem 😞
Hi,my name is Roxanne,I'm currently experiencing difficulties with my Sony Experia M4 Aqua,my screen is FLICKERING, I have tried several things, Shutting the phone down,Rebooted it,but it still Flikker,any suggestions are Welcome and appreciated, Thanx,Regards Roxanne
Hello,
My M4 Aqua Dual E2363 has constant screen flickering. So bad it could trigger seizures lol. Is it a software or hardware issue? I've posted on XDA and here is my full explanation.
""""Hello,
I won this phone on eBay for 23 dollars. Seller mentioned that it is fully functional but screen flickers.
I tested the phone and its fully functional. The phone is in pristine condition with no water damage.
I tried everything to try to get rid of the flickering.
-Updated it to stock Marshmallow.
-Unlocked bootloader & flashed a custom kernel & ROM.
-TWRP wiping didn't help
-Disabled HW Overlays in Dev Options.
-Reflashed Stock Marshmallow Firmware.
Nothing works
Here's what I found out though. The phone doesn't flicker when it is only displaying teext in the entire screen such as in Settings. It'll only flicker when it begins to display images such as when I'm in Chrome or changing my wallpaper. When navigating through the phone the flickering is triggered when displaying images, photos, etc but not text.
Does this have something to do with the hardware itself? Can it be fixed?”"""
Okay so remember it's not the screen that's flickering randomly it's actually being "triggered" when the images are displayed.
