I just got my M and it came with an SD installed, but I want to use a different SD card. How do I get it out? Is there some special trick, or is it just really stuck in there? I had an E1 before this, and the SD card was very easy to remove.
Apparently it gets stuck on the black plastic just before you push it in. Quite common according to the guy that sells the phones. The solution was a small screwdriver to lift up the SD card, then just pull it out with your fingernail.
That sounds wierd. You should be able to put your thumb lightly on the SD-card then drag it backwards to remove the memory card. Don't press down your thumb to hard.
Thanks. I'll take it back to where I got it and ask them to remove it, and if they can't I'll ask for a replacement. I thought perhaps there was some trick to it, like pushing it in more, then out, or perhaps there was a release button that needed to be pushed before you could remove it.
No, it should not be any trick or similar to remove the SD-card. Sounds like a good idea to contact your retailer if you are unable to remove the memory card.
