Hi, XPERIA M4 AQUA to which I constantly fall out GPS signals. Setting up sites I manage, I tried several times to factory settings, I contacted the support but nothing has changed. Someone knows what to do? Perhaps it would help any updates. Thank you for your help.
yep, remove the phone cover if you have one.
I also faced same issue then i installed gps status app and now it works good
I also have the same problem. I belive that hardware works very well, because on gps test phone sees a lot of satelites in a very short time.
Did anyonw try to downgrade to kitkat ?
Same problem here, apparently after update gps stops and starts in a few seconds... this is a recording of the Gps status. Satellites goes to 0 then starts again. Without cover, in safe mode... after factory reset... the same problem.
since the day ,i updated my sony m4 software , my gps does not work , i run for sport and i cant watch my performans lol ths phone has really disappointed me and im not satisfied with it , i ididnt get good credir from the phone for my money i paid for it .Pls someone share an advice except removing the case off the phone , bcz this is not solution .thankyou.
Also experiencing same problems since I updated to Android Marshmallow. On lollipop WiFi wasn't working, and now GPS is completely useless on all apps, be it Google Maps or Nokia Here. So I got lost several times while driving through high traffic abroad, because GPS signal gets constantly lost, and the phone won't lock to any sattelites.
So they screw up key smartphone features like WiFi and GPS on a massive scale, with their own software and don't mind to update it for more than a year!
Never buying a Sony phone again.
