Hi, XPERIA M4 AQUA to which I constantly fall out GPS signals. Setting up sites I manage, I tried several times to factory settings, I contacted the support but nothing has changed. Someone knows what to do? Perhaps it would help any updates. Thank you for your help.
Few other things to try
boot on safe mode
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
if that doesn't work then try reinstalling the latest software with PCC
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Thank you very much. 🙂
Hi, I need advice on my Xperia M4 Aqua not working GPS function. I point settings for high accuracy, even though I have a GPS signal is very weak or no. What about it? We know of any program to support GPS, or the chance that there will be an update to fix this error ?? I tried to restart, safe mode, return to the factory settings and still unchanged.. 😞
