Mostly it is com.android.phone crashed but it shows others too.
The thing is that I'm unable to hard reset the phone either by selecting to do so through phone or trying to do so with the hard buttons. Also getting into "safe mode" doesn't work.
I managed to open ccleaner and it says that it uses just 300 mb of the memory when normaly its at 700
I don't know what to do... Please help me.
ok thanks!
Keep us updated.
