Is there an option to notify when battery is full while charging in m5?
@Ajith5 Are you running 6.0? Do you normally see a message on home screen "Charging and time left"?
Normally the text should change from "charging" to "charged" at 100%.
@Ajith5 Take a look under settings - accesibility, there should be something called play sound when battery is full.
