U using PCC or SUS for Update, or dowload file TFT and using flashtool
Link down FWhttp://forum.xda-developers.com/showthread.php?t=2523368
p/s: Xperia M New fW.............? ? ? ?
Just now I did my update for my phone!
you are saying 3rd step..It means whether it is downloding to PC or while updating your phone
Third step:
1.In first part it will download the software from internet to your PC(it will take awhile)
2.then it will ask you to disconnect your phone from PC -> switch it off->again connect your phone to PC by pressing volume down buton on your phone.(below screen shot after connecting)
3RD STEP MEANS UPDATE. PC DOWNLOAD WAS COMPLETED. MEANS I HAVE TO DISCONNECT USB NOW, RIGHT? THEN TO RE CONNECT IT BY PRESSING DOWN VOLUME KEY? OK, I AM TRYING THAT,. THANKS FOR YOUR SUGECTION.
I JUST DID THAT FRIEND. BUT THAT ICON U SHOWED DIDNT GOT YET.THE PHONE IS CONNECTED NOW WITH PC, BUT THE SAME THINGS I AM NOTICING ON PC SCREEN . PLEASE WAIT... AND MY PHONE IS STILL BLANK ..PLEASE HELP..
SUS is sony update service. Flickering is fixed by update and I didnt notice nething else. Just update using PCC.
Sony.. please list the new additions or patches for the update 15.2.A.2.5. If anyone has properly updated their phone and recognized some improvements and new features then tell please.............
Sony .. an advice for you show the additions and patches list whenever float an update to any device... Please... be user friendly.
I got this patch installed on my M dual phone last week and below are the observtions (there will not be any issue in installing, takes around 35 minutes):
1. No improvements in Camera and music clarity.
2. Useful Gtalk has been replaced by useless Hangouts (and you will not be able to rever to Gtalk unless to root the phone).
3. A new app "Play Games" (which navigates to play store to select games) has been added.
If you are the regular user of Gtalk, then I suggest you not to go for the update.
There is no official note by SONY on what exatly is the fix in this build. However, many users are claiming that camera clarity has been improved. But I still able to see the same image noise.
If I have answered your query, please say kudos
Details on drawbacks with XPERIA M dual (c2004) can be seen in my below thread:
DOne the update..Still I am facing same flickering problem
please someone help me.. how to install new firmware Open source archive for build 15.2.A.2.5
Open source download for Xperia™ M dual (C2004); software version 15.2.A.2.5
After firmware update I am getting camera problem. Capturing some irregular image..really bad. Nothing fixed in this update. we got some applications like hangout,..etc. No other changes
Still,
Flickering problem on lock screen.
I feel Camera became worst than before.
In google navigation app, compass is not working!!(even before update) and etc.
Not satsfied:(
I updated my M DUAL to 15.2.A.2.5 but after taking pictures the preview image in stock camera is distorted but when I checked the picture in gallery it was good. This happens everytime I snap pictures. hope this is the right place to post new firmware problems.
