I have more storage than i should have, It shows 14.58 GB, but when i addup how much where is, then i get 11.78GB.
Probably app data it's not taken into account
Settings > apps > app info > select the app (check streaming, social media apps and chrome) > storage > clear data > repeat as needed > check again.
you can also download this file commander
https://play.google.com/store/apps/details?id=com.mobisystems.fileman&hl=en_US
once you open it you will have few trials to see what's using up the storage, even some app data. tap on the pie graph next to internal storage
I did get some free space, but still it shows more space is being used.
that's odd, I wonder if there's a hidden backup or file, download the file commander and report back, at least you have few more free GB
