Hello,
When on a call (Sent or Receiving) my microphone doesn't work, the other person cannot hear me.
However if I go to speaker phone they hear me fine.
The microphone works fine in diagnostics.
I haven't downloaded any apps recently.
Is there an easy fix to this?
Thanks,
I am having the same problem. Works for call, not for voice recording(WhatsApp etc...) So frustrating!
Same problem. None of the solutions worked for me. Works on speaker phone.
Haw to do this things bot working?..
My M5 mic was not working until I unticked the "block offensive words" Google>settings>voice>block offensive words
Hi, I had this problem with the microphone as well but fortunately it got solved by your idea (Google voice..), but that means I can't use the 'ok google' function anymore, so is there a way to turn it back on and the microphone would still work properly?
P.S thank you still for helping me resolve the microphone issue.
Where do I find that?
I'm having this issue with my Sony Experia Ultra XA1. I don't see the Google voice settings, or the Microphone noise suppression. Is there an alternate name in Ultra XA1 for the same settings that may be causing the voice issue?
Thanks in advance!
Microphone not werking in call
When somebody call me, i cannot hear their voice but i can hear them
Let me when you hear something.
