Hi...
I wanted to know if this memoey would work properly wothout any issuses on (my xperia M5 dual )or no and will it decrease the speed of the phone?
'Kingston Digital 64GB MicroSDXC Class 10'
And thnx..
David.
Hi @davidgamilgeek672003, welcome to the community.
The only way an SD card will effect the performance of your phone is if you install apps on it, and even then it will only effect the app you installed onto the SD card.
This card should be perfectly fine for your Xperia M5
Thnx for your reply 😃
No problem
