Hi
As what the title said, i am having problem on my bluetooth.
I cannot turn it on, it will always say "Unfortunately, Bluetooth share has stopped"
This was after updating from 5.1 to 6.0.
Any way to resolve this?
Hi All,
From several days of research still did not found solution for the issue.
I did, from what i said, the last resort, software repair, IT DID FIX the problem.
How sad that i need to restore all my apps and data etc.
does this happen when you are in safe mode?
since you recently updated you can try software repair using Xperia Companion
Had tried it on safe mode. The issue still persists, still won't let me turn on the bluetooth.
I wish repair should be the last resort, since it would reset the device and would take time for me to backup all my important files.
