Hello everyone,
I am prashast from India and i recently bought my new xperia device m4 e2363 from beginning it was charging very slow like 1% increases in 8-9minute.
That's rather odd, you might want to get your phone inspected by your local Xperia Care
Well, the charging depends on a lot of factors. Do you charge via USB on the computer or via the wall socket? Are you using the phone while charging?
Are you using the phone while charging? perhaps playing heavy games? or using a computer to charge your phone instead of a wall charger
@Prashast wrote:
No I don't use my phone while charging and I charge only through stock sony charger which was provided with my phone and when I connect my phone to pc through usb my pc doesn't recognize it. My charging speed is 7-9 minutes 1%.
that sounds like it is a problem with the usb cable try any other usb cable lying around
mine is also charging slow but I am using a dollarstore usb cable I suggest buy an sony usb cable it should make charging faster fix connection to pc
